Time Before: 0.02397 seconds
Time After: 0.02863 seconds
Time Taken: 0.00466 seconds
Time Before: 0.02871 seconds
Time After: 0.02920 seconds
Time Before: 0.02939 seconds
Time After: 0.02951 seconds
Time Before: 0.03031 seconds
Time After: 0.03282 seconds
Time Taken: 0.00252 seconds
Time Before: 0.02957 seconds
Time After: 0.03709 seconds
Time Taken: 0.00751 seconds
Time Before: 0.04489 seconds
Time After: 0.04527 seconds
Time Before: 0.04766 seconds
Time After: 0.04910 seconds
Time Before: 0.04416 seconds
Time After: 0.04943 seconds
Time Taken: 0.00527 seconds
Time Before: 0.10671 seconds
Time After: 0.10684 seconds
Time Before: 0.12639 seconds
Time After: 0.12766 seconds
End call of global.php: 0.13000893592834
Time Before: 0.13721 seconds
Time After: 0.13734 seconds
Time Before: 0.13987 seconds
Time After: 0.14132 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=18484', badlocation = 1
Time Before: 0.16122 seconds
Time After: 0.20008 seconds
Time Taken: 0.03886 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.15984392166138 seconds with 9 queries, spending 0.046793699264526 doing MySQL queries and 0.11305022239685 doing PHP things.
