Time Before: 0.02009 seconds
Time After: 0.02387 seconds
Time Taken: 0.00378 seconds
Time Before: 0.02398 seconds
Time After: 0.02449 seconds
Time Before: 0.02483 seconds
Time After: 0.02498 seconds
Time Before: 0.02579 seconds
Time After: 0.02839 seconds
Time Taken: 0.00260 seconds
Time Before: 0.02505 seconds
Time After: 0.03239 seconds
Time Taken: 0.00734 seconds
Time Before: 0.04193 seconds
Time After: 0.04232 seconds
Time Before: 0.04473 seconds
Time After: 0.04597 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04136 seconds
Time After: 0.04617 seconds
Time Taken: 0.00481 seconds
Memory After: 2,261.719 KB
Time Before: 0.09047 seconds
Time After: 0.09063 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10673 seconds
Time After: 0.10797 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.11909 seconds
Time After: 0.11933 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12168 seconds
Time After: 0.12311 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=18498' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14005 seconds
Time After: 0.14033 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
