Time Before: 0.00198 seconds
Time After: 0.00255 seconds
Time Taken: 0.00057 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00266 seconds
Time After: 0.00331 seconds
Time Taken: 0.00065 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00355 seconds
Time After: 0.00369 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00429 seconds
Time After: 0.00656 seconds
Time Taken: 0.00227 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00374 seconds
Time After: 0.01115 seconds
Time Taken: 0.00741 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01302 seconds
Time After: 0.01356 seconds
Time Taken: 0.00054 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01584 seconds
Time After: 0.01707 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01236 seconds
Time After: 0.01724 seconds
Time Taken: 0.00488 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02371 seconds
Time After: 0.02384 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02581 seconds
Time After: 0.02703 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.028649806976318
Time Before: 0.02983 seconds
Time After: 0.03003 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03183 seconds
Time After: 0.03323 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=18544'
Time Before: 0.04702 seconds
Time After: 0.04740 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.046127796173096 seconds with 9 queries, spending 0.008162260055542 doing MySQL queries and 0.037965536117554 doing PHP things.
