Time Before: 0.02824 seconds
Time After: 0.03943 seconds
Time Taken: 0.01119 seconds
Time Before: 0.03955 seconds
Time After: 0.04021 seconds
Time Taken: 0.00066 seconds
Time Before: 0.04044 seconds
Time After: 0.04057 seconds
Time Before: 0.04149 seconds
Time After: 0.04397 seconds
Time Taken: 0.00248 seconds
Time Before: 0.04064 seconds
Time After: 0.04859 seconds
Time Taken: 0.00795 seconds
Time Before: 0.06302 seconds
Time After: 0.06328 seconds
Time Before: 0.06638 seconds
Time After: 0.06761 seconds
Time Before: 0.06226 seconds
Time After: 0.06788 seconds
Time Taken: 0.00562 seconds
Time Before: 0.11649 seconds
Time After: 0.11663 seconds
Time Before: 0.15151 seconds
Time After: 0.15274 seconds
Time Before: 0.16818 seconds
Time After: 0.16834 seconds
Time Before: 0.17106 seconds
Time After: 0.17250 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=18562' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.19321 seconds
Time After: 0.19346 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
