Time Before: 0.02793 seconds
Time After: 0.03596 seconds
Time Taken: 0.00803 seconds
Time Before: 0.03603 seconds
Time After: 0.03657 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03685 seconds
Time After: 0.03699 seconds
Time Before: 0.03782 seconds
Time After: 0.04110 seconds
Time Taken: 0.00328 seconds
Time Before: 0.03706 seconds
Time After: 0.04507 seconds
Time Taken: 0.00801 seconds
Time Before: 0.05850 seconds
Time After: 0.05873 seconds
Time Before: 0.06037 seconds
Time After: 0.06156 seconds
Time Before: 0.05781 seconds
Time After: 0.06176 seconds
Time Taken: 0.00396 seconds
Time Before: 0.10589 seconds
Time After: 0.10615 seconds
Time Before: 0.12325 seconds
Time After: 0.12449 seconds
Time Before: 0.14154 seconds
Time After: 0.14173 seconds
Time Before: 0.14516 seconds
Time After: 0.14671 seconds
Time Taken: 0.00156 seconds
UPDATE session SET lastactivity = 1785298142, location = '/forums/private.php?do=newpm&explain=1&u=18564' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.16594 seconds
Time After: 0.16617 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
