Time Before: 0.00269 seconds
Time After: 0.00347 seconds
Time Taken: 0.00078 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00358 seconds
Time After: 0.00409 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00437 seconds
Time After: 0.00453 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00543 seconds
Time After: 0.00794 seconds
Time Taken: 0.00251 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00461 seconds
Time After: 0.01247 seconds
Time Taken: 0.00786 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01467 seconds
Time After: 0.01568 seconds
Time Taken: 0.00101 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.01822 seconds
Time After: 0.01947 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01406 seconds
Time After: 0.01968 seconds
Time Taken: 0.00561 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.02541 seconds
Time After: 0.02557 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.02746 seconds
Time After: 0.02876 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
End call of global.php: 0.030411005020142
Time Before: 0.03154 seconds
Time After: 0.03167 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03374 seconds
Time After: 0.03568 seconds
Time Taken: 0.00194 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
SET lastactivity = 1788990457, location = '/forums/private.php?do=newpm&explain=1&u=18566'
Time Before: 0.05067 seconds
Time After: 0.05106 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
Page generated in 0.049773931503296 seconds with 9 queries, spending 0.0093722343444824 doing MySQL queries and 0.040401697158813 doing PHP things.
