Time Before: 0.00674 seconds
Time After: 0.00885 seconds
Time Taken: 0.00211 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.00897 seconds
Time After: 0.00945 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.00972 seconds
Time After: 0.00984 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.01063 seconds
Time After: 0.01367 seconds
Time Taken: 0.00304 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.00990 seconds
Time After: 0.01709 seconds
Time Taken: 0.00719 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.02037 seconds
Time After: 0.02074 seconds
Time Before: 0.02308 seconds
Time After: 0.02437 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01976 seconds
Time After: 0.02458 seconds
Time Taken: 0.00482 seconds
Memory After: 2,261.820 KB
Time Before: 0.03754 seconds
Time After: 0.03765 seconds
Memory Before: 2,815.414 KB
Memory After: 2,815.930 KB
Time Before: 0.04282 seconds
Time After: 0.04414 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,903.719 KB
Memory After: 2,904.313 KB
End call of global.php: 0.046396970748901
Time Before: 0.05042 seconds
Time After: 0.05059 seconds
Memory Before: 3,540.484 KB
Memory After: 3,540.914 KB
Time Before: 0.05321 seconds
Time After: 0.05470 seconds
Memory Before: 3,822.031 KB
Memory After: 3,823.703 KB
Memory Used: 1.672 KB
SET lastactivity = 1785276063, location = '/forums/private.php?do=newpm&explain=1&u=18635', badlocation = 1
Time Before: 0.07093 seconds
Time After: 0.07126 seconds
Memory Before: 4,296.156 KB
Memory After: 4,296.367 KB
Page generated in 0.069928884506226 seconds with 9 queries, spending 0.0087306499481201 doing MySQL queries and 0.061198234558105 doing PHP things.
