Time Before: 0.00249 seconds
Time After: 0.00311 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00321 seconds
Time After: 0.00369 seconds
Time Before: 0.00394 seconds
Time After: 0.00410 seconds
Time Before: 0.00500 seconds
Time After: 0.00701 seconds
Time Taken: 0.00201 seconds
Time Before: 0.00419 seconds
Time After: 0.01048 seconds
Time Taken: 0.00629 seconds
Time Before: 0.01224 seconds
Time After: 0.01265 seconds
Time Before: 0.01564 seconds
Time After: 0.01686 seconds
Time Before: 0.01164 seconds
Time After: 0.01710 seconds
Time Taken: 0.00546 seconds
Time Before: 0.02408 seconds
Time After: 0.02428 seconds
Time Before: 0.02665 seconds
Time After: 0.02786 seconds
End call of global.php: 0.029546022415161
Time Before: 0.03101 seconds
Time After: 0.03113 seconds
Time Before: 0.03326 seconds
Time After: 0.03480 seconds
Time Taken: 0.00154 seconds
SET lastactivity = 1782960381, location = '/forums/private.php?do=newpm&explain=1&u=18726', badlocation = 1
Time Before: 0.05437 seconds
Time After: 0.05473 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.052568197250366 seconds with 9 queries, spending 0.0076971054077148 doing MySQL queries and 0.044871091842651 doing PHP things.
