Time Before: 0.00332 seconds
Time After: 0.00424 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00431 seconds
Time After: 0.00491 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00519 seconds
Time After: 0.00534 seconds
Time Before: 0.00636 seconds
Time After: 0.00916 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00542 seconds
Time After: 0.01414 seconds
Time Taken: 0.00873 seconds
Time Before: 0.01612 seconds
Time After: 0.01657 seconds
Time Before: 0.01918 seconds
Time After: 0.02044 seconds
Time Before: 0.01544 seconds
Time After: 0.02062 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02592 seconds
Time After: 0.02609 seconds
Time Before: 0.04362 seconds
Time After: 0.04498 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.046809911727905
Time Before: 0.04822 seconds
Time After: 0.04838 seconds
Time Before: 0.05046 seconds
Time After: 0.05188 seconds
SET lastactivity = 1789104970, location = '/forums/private.php?do=newpm&explain=1&u=18742', badlocation = 1
Time Before: 0.06427 seconds
Time After: 0.06465 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.06336784362793 seconds with 9 queries, spending 0.0087575912475586 doing MySQL queries and 0.054610252380371 doing PHP things.
