Time Before: 0.00190 seconds
Time After: 0.00246 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00253 seconds
Time After: 0.00327 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00354 seconds
Time After: 0.00372 seconds
Time Before: 0.00450 seconds
Time After: 0.00701 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00377 seconds
Time After: 0.01042 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01221 seconds
Time After: 0.01243 seconds
Time Before: 0.01527 seconds
Time After: 0.01663 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01163 seconds
Time After: 0.01680 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02177 seconds
Time After: 0.02201 seconds
Time Before: 0.02416 seconds
Time After: 0.02544 seconds
Time Before: 0.02859 seconds
Time After: 0.02876 seconds
Time Before: 0.03087 seconds
Time After: 0.03245 seconds
Time Taken: 0.00158 seconds
UPDATE session SET lastactivity = 1769227914, location = '/forums/private.php?do=newpm&explain=1&u=18775', badlocation = 1 WHERE sessionhash = '84a1ba763b341c65c6e779f4d27b10fd'
Time Before: 0.04530 seconds
Time After: 0.04558 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
