Time Before: 0.00151 seconds
Time After: 0.00208 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00219 seconds
Time After: 0.00276 seconds
Time Before: 0.00302 seconds
Time After: 0.00314 seconds
Time Before: 0.00383 seconds
Time After: 0.00656 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00320 seconds
Time After: 0.00995 seconds
Time Taken: 0.00676 seconds
Time Before: 0.01173 seconds
Time After: 0.01210 seconds
Time Before: 0.01455 seconds
Time After: 0.01573 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01116 seconds
Time After: 0.01591 seconds
Time Taken: 0.00475 seconds
Time Before: 0.02134 seconds
Time After: 0.02150 seconds
Time Before: 0.02354 seconds
Time After: 0.02482 seconds
Time Before: 0.02884 seconds
Time After: 0.02902 seconds
Time Before: 0.03171 seconds
Time After: 0.03316 seconds
UPDATE session SET lastactivity = 1785364765, location = '/forums/private.php?do=newpm&explain=1&u=18850', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04587 seconds
Time After: 0.04616 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
