Time Before: 0.01643 seconds
Time After: 0.02325 seconds
Time Taken: 0.00682 seconds
Time Before: 0.02334 seconds
Time After: 0.02410 seconds
Time Taken: 0.00076 seconds
Time Before: 0.02437 seconds
Time After: 0.02556 seconds
Time Before: 0.02703 seconds
Time After: 0.03176 seconds
Time Taken: 0.00472 seconds
Time Before: 0.02562 seconds
Time After: 0.03598 seconds
Time Taken: 0.01037 seconds
Time Before: 0.04539 seconds
Time After: 0.04587 seconds
Time Before: 0.04893 seconds
Time After: 0.05012 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04461 seconds
Time After: 0.05033 seconds
Time Taken: 0.00572 seconds
Memory After: 2,261.719 KB
Time Before: 0.07111 seconds
Time After: 0.07186 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09151 seconds
Time After: 0.09275 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.10588 seconds
Time After: 0.10604 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11087 seconds
Time After: 0.11274 seconds
Time Taken: 0.00187 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=1886', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.13400 seconds
Time After: 0.14290 seconds
Time Taken: 0.00890 seconds
Memory Before: 4,287.508 KB
Memory After: 4,287.734 KB
