Time Before: 0.00278 seconds
Time After: 0.00340 seconds
Time Taken: 0.00061 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00347 seconds
Time After: 0.00405 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00429 seconds
Time After: 0.00446 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00515 seconds
Time After: 0.00773 seconds
Time Taken: 0.00258 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00451 seconds
Time After: 0.01242 seconds
Time Taken: 0.00792 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01441 seconds
Time After: 0.01485 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01731 seconds
Time After: 0.01860 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.01376 seconds
Time After: 0.01878 seconds
Time Taken: 0.00502 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.02493 seconds
Time After: 0.02518 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.03210 seconds
Time After: 0.03338 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.035010099411011
Time Before: 0.04295 seconds
Time After: 0.04315 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.04536 seconds
Time After: 0.04684 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772715729, location = '/forums/private.php?do=newpm&explain=1&u=1896'
Time Before: 0.06017 seconds
Time After: 0.06048 seconds
Memory Before: 5,997.727 KB
Memory After: 5,997.945 KB
Page generated in 0.059263944625854 seconds with 9 queries, spending 0.0085937976837158 doing MySQL queries and 0.050670146942139 doing PHP things.
