Time Before: 0.00946 seconds
Time After: 0.01549 seconds
Time Taken: 0.00603 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.01559 seconds
Time After: 0.01610 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.01643 seconds
Time After: 0.01660 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.01745 seconds
Time After: 0.01988 seconds
Time Taken: 0.00243 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.01667 seconds
Time After: 0.02403 seconds
Time Taken: 0.00735 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.03194 seconds
Time After: 0.03236 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.03508 seconds
Time After: 0.03632 seconds
Memory Before: 2,770.078 KB
Memory After: 2,769.938 KB
Time Before: 0.03107 seconds
Time After: 0.03657 seconds
Time Taken: 0.00550 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.297 KB
Memory Used: 133.125 KB
Time Before: 0.05562 seconds
Time After: 0.05579 seconds
Memory Before: 3,436.438 KB
Memory After: 3,436.953 KB
Time Before: 0.06958 seconds
Time After: 0.07082 seconds
Memory Before: 3,524.234 KB
Memory After: 3,524.828 KB
Time Before: 0.07980 seconds
Time After: 0.07998 seconds
Memory Before: 4,162.117 KB
Memory After: 4,162.547 KB
Time Before: 0.08250 seconds
Time After: 0.08422 seconds
Time Taken: 0.00172 seconds
Memory Before: 4,443.680 KB
Memory After: 4,445.367 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=19092', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.10356 seconds
Time After: 0.10384 seconds
Memory Before: 4,921.977 KB
Memory After: 4,922.203 KB
