Time Before: 0.01350 seconds
Time After: 0.01716 seconds
Time Taken: 0.00367 seconds
Time Before: 0.01727 seconds
Time After: 0.01780 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01808 seconds
Time After: 0.01824 seconds
Time Before: 0.01918 seconds
Time After: 0.02215 seconds
Time Taken: 0.00297 seconds
Time Before: 0.01832 seconds
Time After: 0.02663 seconds
Time Taken: 0.00832 seconds
Time Before: 0.03337 seconds
Time After: 0.03380 seconds
Time Before: 0.03711 seconds
Time After: 0.03842 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03096 seconds
Time After: 0.03863 seconds
Time Taken: 0.00767 seconds
Time Before: 0.06350 seconds
Time After: 0.06367 seconds
Time Before: 0.07565 seconds
Time After: 0.07698 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.079261064529419
Time Before: 0.08779 seconds
Time After: 0.08797 seconds
Time Before: 0.09126 seconds
Time After: 0.09275 seconds
SET lastactivity = 1785474787, location = '/forums/private.php?do=newpm&explain=1&u=1927', badlocation = 1
WHERE sessionhash = 'f787d15acff2abe23491441932164758'
Time Before: 0.11205 seconds
Time After: 0.11243 seconds
Memory Before: 4,288.563 KB
Memory After: 4,288.773 KB
Page generated in 0.1108410358429 seconds with 9 queries, spending 0.0089514255523682 doing MySQL queries and 0.10188961029053 doing PHP things.
