Time Before: 0.00155 seconds
Time After: 0.00211 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00218 seconds
Time After: 0.00281 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00306 seconds
Time After: 0.00317 seconds
Time Before: 0.00386 seconds
Time After: 0.00635 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00322 seconds
Time After: 0.00973 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01159 seconds
Time After: 0.01201 seconds
Time Before: 0.01422 seconds
Time After: 0.01550 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01095 seconds
Time After: 0.01569 seconds
Time Taken: 0.00474 seconds
Memory After: 2,261.836 KB
Time Before: 0.02220 seconds
Time After: 0.02239 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02429 seconds
Time After: 0.02551 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.027263164520264
Time Before: 0.02878 seconds
Time After: 0.02909 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03119 seconds
Time After: 0.03262 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788920110, location = '/forums/private.php?do=newpm&explain=1&u=19305', badlocation = 1
Time Before: 0.04512 seconds
Time After: 0.04543 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.044016122817993 seconds with 9 queries, spending 0.0083730220794678 doing MySQL queries and 0.035643100738525 doing PHP things.
