Time Before: 0.00175 seconds
Time After: 0.00227 seconds
Time Before: 0.00233 seconds
Time After: 0.00275 seconds
Time Before: 0.00299 seconds
Time After: 0.00312 seconds
Time Before: 0.00391 seconds
Time After: 0.00624 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00320 seconds
Time After: 0.00979 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01167 seconds
Time After: 0.01209 seconds
Time Before: 0.01370 seconds
Time After: 0.01490 seconds
Time Before: 0.01106 seconds
Time After: 0.01515 seconds
Time Taken: 0.00409 seconds
Time Before: 0.02163 seconds
Time After: 0.02177 seconds
Time Before: 0.02420 seconds
Time After: 0.02546 seconds
Time Before: 0.02850 seconds
Time After: 0.02867 seconds
Time Before: 0.03077 seconds
Time After: 0.03222 seconds
UPDATE session SET lastactivity = 1785342044, location = '/forums/private.php?do=newpm&explain=1&u=19571' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04636 seconds
Time After: 0.04668 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
