Time Before: 0.00259 seconds
Time After: 0.00308 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00316 seconds
Time After: 0.00357 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00380 seconds
Time After: 0.00394 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00480 seconds
Time After: 0.00757 seconds
Time Taken: 0.00277 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00402 seconds
Time After: 0.01289 seconds
Time Taken: 0.00888 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01531 seconds
Time After: 0.01575 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01850 seconds
Time After: 0.01972 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01457 seconds
Time After: 0.01998 seconds
Time Taken: 0.00540 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02777 seconds
Time After: 0.02791 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.03816 seconds
Time After: 0.03941 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.042023897171021
Time Before: 0.04890 seconds
Time After: 0.04904 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.05149 seconds
Time After: 0.05294 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=19610', badlocation = 1
WHERE sessionhash = 'cb23636bbd36247f3b1133fdf383bca3'
Time Before: 0.06728 seconds
Time After: 0.06756 seconds
Memory Before: 5,998.492 KB
Memory After: 5,998.711 KB
Page generated in 0.066283941268921 seconds with 9 queries, spending 0.0082402229309082 doing MySQL queries and 0.058043718338013 doing PHP things.
