Time Before: 0.00277 seconds
Time After: 0.00339 seconds
Time Taken: 0.00062 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00347 seconds
Time After: 0.00407 seconds
Time Taken: 0.00060 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00433 seconds
Time After: 0.00446 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00535 seconds
Time After: 0.00792 seconds
Time Taken: 0.00257 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00454 seconds
Time After: 0.01293 seconds
Time Taken: 0.00840 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01537 seconds
Time After: 0.01585 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01836 seconds
Time After: 0.01961 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.01464 seconds
Time After: 0.01985 seconds
Time Taken: 0.00521 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.02676 seconds
Time After: 0.02693 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.03368 seconds
Time After: 0.03493 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.036715984344482
Time Before: 0.04286 seconds
Time After: 0.04306 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.04535 seconds
Time After: 0.04680 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772947139, location = '/forums/private.php?do=newpm&explain=1&u=19639'
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.06025 seconds
Time After: 0.06053 seconds
Memory Before: 5,997.766 KB
Memory After: 5,997.984 KB
Page generated in 0.059302806854248 seconds with 9 queries, spending 0.0083773136138916 doing MySQL queries and 0.050925493240356 doing PHP things.
