Time Before: 0.00222 seconds
Time After: 0.00321 seconds
Time Taken: 0.00099 seconds
Time Before: 0.00328 seconds
Time After: 0.00465 seconds
Time Taken: 0.00136 seconds
Time Before: 0.00519 seconds
Time After: 0.00535 seconds
Time Before: 0.00623 seconds
Time After: 0.00874 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00544 seconds
Time After: 0.01425 seconds
Time Taken: 0.00882 seconds
Time Before: 0.01811 seconds
Time After: 0.01837 seconds
Time Before: 0.02075 seconds
Time After: 0.02207 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01691 seconds
Time After: 0.02231 seconds
Time Taken: 0.00540 seconds
Time Before: 0.02991 seconds
Time After: 0.03019 seconds
Time Before: 0.03303 seconds
Time After: 0.03433 seconds
End call of global.php: 0.036103963851929
Time Before: 0.03731 seconds
Time After: 0.03748 seconds
Time Before: 0.03953 seconds
Time After: 0.04100 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=19730'
Time Before: 0.05463 seconds
Time After: 0.05491 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.053646087646484 seconds with 9 queries, spending 0.0091266632080078 doing MySQL queries and 0.044519424438477 doing PHP things.
