Time Before: 0.02628 seconds
Time After: 0.03472 seconds
Time Taken: 0.00844 seconds
Time Before: 0.03481 seconds
Time After: 0.03517 seconds
Time Before: 0.03542 seconds
Time After: 0.03554 seconds
Time Before: 0.03628 seconds
Time After: 0.03814 seconds
Time Taken: 0.00186 seconds
Time Before: 0.03559 seconds
Time After: 0.04198 seconds
Time Taken: 0.00639 seconds
Time Before: 0.05240 seconds
Time After: 0.05276 seconds
Time Before: 0.05465 seconds
Time After: 0.05582 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05167 seconds
Time After: 0.05606 seconds
Time Taken: 0.00439 seconds
Memory After: 2,261.719 KB
Time Before: 0.11138 seconds
Time After: 0.11150 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.12870 seconds
Time After: 0.12995 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.13204789161682
Time Before: 0.14396 seconds
Time After: 0.14414 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.14706 seconds
Time After: 0.14858 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=19763'
Time Before: 0.16638 seconds
Time After: 0.16666 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.16539287567139 seconds with 9 queries, spending 0.0072174072265625 doing MySQL queries and 0.15817546844482 doing PHP things.
