Time Before: 0.01727 seconds
Time After: 0.02268 seconds
Time Taken: 0.00541 seconds
Time Before: 0.02278 seconds
Time After: 0.02315 seconds
Time Before: 0.02337 seconds
Time After: 0.02355 seconds
Time Before: 0.02434 seconds
Time After: 0.02653 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02361 seconds
Time After: 0.03052 seconds
Time Taken: 0.00690 seconds
Time Before: 0.03635 seconds
Time After: 0.03674 seconds
Time Before: 0.03832 seconds
Time After: 0.03950 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03552 seconds
Time After: 0.03976 seconds
Time Taken: 0.00425 seconds
Time Before: 0.07048 seconds
Time After: 0.07066 seconds
Time Before: 0.08222 seconds
Time After: 0.08346 seconds
End call of global.php: 0.085960865020752
Time Before: 0.09035 seconds
Time After: 0.09053 seconds
Time Before: 0.09290 seconds
Time After: 0.09434 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=19847'
Time Before: 0.11049 seconds
Time After: 0.11099 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.10942697525024 seconds with 9 queries, spending 0.0078432559967041 doing MySQL queries and 0.10158371925354 doing PHP things.
