Time Before: 0.00169 seconds
Time After: 0.00217 seconds
Time Before: 0.00224 seconds
Time After: 0.00271 seconds
Time Before: 0.00295 seconds
Time After: 0.00309 seconds
Time Before: 0.00395 seconds
Time After: 0.00640 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00317 seconds
Time After: 0.00976 seconds
Time Taken: 0.00659 seconds
Time Before: 0.01153 seconds
Time After: 0.01192 seconds
Time Before: 0.01532 seconds
Time After: 0.01777 seconds
Time Before: 0.01097 seconds
Time After: 0.01800 seconds
Time Taken: 0.00703 seconds
Time Before: 0.02439 seconds
Time After: 0.02455 seconds
Time Before: 0.02711 seconds
Time After: 0.02837 seconds
Time Before: 0.03189 seconds
Time After: 0.03204 seconds
Time Before: 0.03484 seconds
Time After: 0.03627 seconds
UPDATE session SET lastactivity = 1784811792, location = '/forums/private.php?do=newpm&explain=1&u=19891', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.05009 seconds
Time After: 0.05040 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
