Time Before: 0.00328 seconds
Time After: 0.00404 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00412 seconds
Time After: 0.00487 seconds
Time Before: 0.00515 seconds
Time After: 0.00531 seconds
Time Before: 0.00612 seconds
Time After: 0.00862 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00539 seconds
Time After: 0.01203 seconds
Time Taken: 0.00664 seconds
Time Before: 0.01410 seconds
Time After: 0.01448 seconds
Time Before: 0.01729 seconds
Time After: 0.01846 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01350 seconds
Time After: 0.01869 seconds
Time Taken: 0.00519 seconds
Memory After: 2,261.836 KB
Time Before: 0.02449 seconds
Time After: 0.02460 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02675 seconds
Time After: 0.02796 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03141 seconds
Time After: 0.03182 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03381 seconds
Time After: 0.03526 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789038830, location = '/forums/private.php?do=newpm&explain=1&u=19949' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04797 seconds
Time After: 0.04854 seconds
Time Taken: 0.00056 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
