Time Before: 0.00162 seconds
Time After: 0.00214 seconds
Time Before: 0.00222 seconds
Time After: 0.00305 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00354 seconds
Time After: 0.00371 seconds
Time Before: 0.00451 seconds
Time After: 0.00710 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00378 seconds
Time After: 0.01162 seconds
Time Taken: 0.00784 seconds
Time Before: 0.01347 seconds
Time After: 0.01369 seconds
Time Before: 0.01623 seconds
Time After: 0.01751 seconds
Time Before: 0.01289 seconds
Time After: 0.01773 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02846 seconds
Time After: 0.02866 seconds
Time Before: 0.05105 seconds
Time After: 0.05238 seconds
Time Taken: 0.00133 seconds
Time Before: 0.05768 seconds
Time After: 0.05787 seconds
Time Before: 0.06143 seconds
Time After: 0.06290 seconds
UPDATE session SET lastactivity = 1782868436, location = '/forums/private.php?do=newpm&explain=1&u=19989', badlocation = 1 WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.07782 seconds
Time After: 0.07806 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
