Time Before: 0.00146 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00257 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00280 seconds
Time After: 0.00292 seconds
Time Before: 0.00364 seconds
Time After: 0.00620 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00297 seconds
Time After: 0.00962 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01200 seconds
Time After: 0.01250 seconds
Time Before: 0.01602 seconds
Time After: 0.01733 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01126 seconds
Time After: 0.01751 seconds
Time Taken: 0.00625 seconds
Time Before: 0.02413 seconds
Time After: 0.02426 seconds
Time Before: 0.02630 seconds
Time After: 0.02762 seconds
End call of global.php: 0.02935791015625
Time Before: 0.03088 seconds
Time After: 0.03101 seconds
Time Before: 0.03307 seconds
Time After: 0.03447 seconds
Time Taken: 0.00139 seconds
SET lastactivity = 1789092288, location = '/forums/private.php?do=newpm&explain=1&u=20131', badlocation = 1
Time Before: 0.04766 seconds
Time After: 0.04801 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.046734094619751 seconds with 9 queries, spending 0.0083608627319336 doing MySQL queries and 0.038373231887817 doing PHP things.
