Time Before: 0.02266 seconds
Time After: 0.03178 seconds
Time Taken: 0.00911 seconds
Time Before: 0.03186 seconds
Time After: 0.03236 seconds
Time Before: 0.03259 seconds
Time After: 0.03274 seconds
Time Before: 0.03352 seconds
Time After: 0.03601 seconds
Time Taken: 0.00249 seconds
Time Before: 0.03280 seconds
Time After: 0.03972 seconds
Time Taken: 0.00691 seconds
Time Before: 0.04492 seconds
Time After: 0.04528 seconds
Time Before: 0.04787 seconds
Time After: 0.04909 seconds
Time Before: 0.04424 seconds
Time After: 0.04931 seconds
Time Taken: 0.00508 seconds
Time Before: 0.08288 seconds
Time After: 0.08303 seconds
Time Before: 0.10149 seconds
Time After: 0.10271 seconds
End call of global.php: 0.1046040058136
Time Before: 0.11094 seconds
Time After: 0.11110 seconds
Time Before: 0.11334 seconds
Time After: 0.11498 seconds
Time Taken: 0.00164 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=20260'
Time Before: 0.13025 seconds
Time After: 0.13051 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.1292130947113 seconds with 9 queries, spending 0.0081338882446289 doing MySQL queries and 0.12107920646667 doing PHP things.
