Time Before: 0.02251 seconds
Time After: 0.03165 seconds
Time Taken: 0.00915 seconds
Time Before: 0.03176 seconds
Time After: 0.03241 seconds
Time Taken: 0.00064 seconds
Time Before: 0.03264 seconds
Time After: 0.03279 seconds
Time Before: 0.03356 seconds
Time After: 0.03564 seconds
Time Taken: 0.00208 seconds
Time Before: 0.03286 seconds
Time After: 0.03976 seconds
Time Taken: 0.00690 seconds
Time Before: 0.04580 seconds
Time After: 0.04618 seconds
Time Before: 0.05185 seconds
Time After: 0.05309 seconds
Time Before: 0.04515 seconds
Time After: 0.05332 seconds
Time Taken: 0.00817 seconds
Time Before: 0.09489 seconds
Time After: 0.09505 seconds
Time Before: 0.11390 seconds
Time After: 0.11517 seconds
Time Before: 0.12661 seconds
Time After: 0.12681 seconds
Time Before: 0.12935 seconds
Time After: 0.13079 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=20279', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14878 seconds
Time After: 0.14908 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
