Time Before: 0.01668 seconds
Time After: 0.02194 seconds
Time Taken: 0.00526 seconds
Time Before: 0.02206 seconds
Time After: 0.02252 seconds
Time Before: 0.02281 seconds
Time After: 0.02291 seconds
Time Taken: 0.00010 seconds
Time Before: 0.02370 seconds
Time After: 0.02613 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02298 seconds
Time After: 0.03023 seconds
Time Taken: 0.00725 seconds
Time Before: 0.03685 seconds
Time After: 0.03728 seconds
Time Before: 0.03988 seconds
Time After: 0.04114 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03608 seconds
Time After: 0.04135 seconds
Memory After: 2,261.836 KB
Time Before: 0.06444 seconds
Time After: 0.06462 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08002 seconds
Time After: 0.08133 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.09023 seconds
Time After: 0.09039 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.09276 seconds
Time After: 0.09425 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788919771, location = '/forums/private.php?do=newpm&explain=1&u=20339' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.11090 seconds
Time After: 0.11115 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
