Time Before: 0.00140 seconds
Time After: 0.00193 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00200 seconds
Time After: 0.00259 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00286 seconds
Time After: 0.00302 seconds
Time Before: 0.00370 seconds
Time After: 0.00618 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00307 seconds
Time After: 0.00966 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01176 seconds
Time After: 0.01219 seconds
Time Before: 0.01370 seconds
Time After: 0.01497 seconds
Time Before: 0.01115 seconds
Time After: 0.01516 seconds
Time Taken: 0.00400 seconds
Time Before: 0.02036 seconds
Time After: 0.02059 seconds
Time Before: 0.02309 seconds
Time After: 0.02436 seconds
End call of global.php: 0.026716947555542
Time Before: 0.02791 seconds
Time After: 0.02814 seconds
Time Before: 0.03014 seconds
Time After: 0.03159 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=20383'
Time Before: 0.04426 seconds
Time After: 0.04459 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.043349027633667 seconds with 9 queries, spending 0.0084671974182129 doing MySQL queries and 0.034881830215454 doing PHP things.
