Time Before: 0.00144 seconds
Time After: 0.00210 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00223 seconds
Time After: 0.00275 seconds
Time Before: 0.00297 seconds
Time After: 0.00312 seconds
Time Before: 0.00381 seconds
Time After: 0.00626 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00317 seconds
Time After: 0.00964 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01146 seconds
Time After: 0.01186 seconds
Time Before: 0.01426 seconds
Time After: 0.01546 seconds
Time Before: 0.01089 seconds
Time After: 0.01563 seconds
Time Taken: 0.00474 seconds
Time Before: 0.02243 seconds
Time After: 0.02271 seconds
Time Before: 0.02461 seconds
Time After: 0.02587 seconds
Time Before: 0.02878 seconds
Time After: 0.02892 seconds
Time Before: 0.03086 seconds
Time After: 0.03229 seconds
UPDATE session SET lastactivity = 1785275996, location = '/forums/private.php?do=newpm&explain=1&u=20487' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04484 seconds
Time After: 0.04512 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
