Time Before: 0.00981 seconds
Time After: 0.01239 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01249 seconds
Time After: 0.01304 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01333 seconds
Time After: 0.01351 seconds
Time Before: 0.01430 seconds
Time After: 0.01766 seconds
Time Taken: 0.00336 seconds
Time Before: 0.01359 seconds
Time After: 0.02234 seconds
Time Taken: 0.00875 seconds
Time Before: 0.02775 seconds
Time After: 0.02818 seconds
Time Before: 0.03075 seconds
Time After: 0.03202 seconds
Time Before: 0.02703 seconds
Time After: 0.03224 seconds
Time Taken: 0.00521 seconds
Time Before: 0.04591 seconds
Time After: 0.04608 seconds
Time Before: 0.04933 seconds
Time After: 0.05063 seconds
End call of global.php: 0.053656101226807
Time Before: 0.05733 seconds
Time After: 0.05751 seconds
Time Before: 0.06021 seconds
Time After: 0.06172 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1785386323, location = '/forums/private.php?do=newpm&explain=1&u=20525'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.08243 seconds
Time After: 0.08880 seconds
Time Taken: 0.00636 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.081273078918457 seconds with 9 queries, spending 0.015311002731323 doing MySQL queries and 0.065962076187134 doing PHP things.
