Time Before: 0.03030 seconds
Time After: 0.03999 seconds
Time Taken: 0.00969 seconds
Time Before: 0.04011 seconds
Time After: 0.04057 seconds
Time Before: 0.04085 seconds
Time After: 0.04100 seconds
Time Before: 0.04180 seconds
Time After: 0.04431 seconds
Time Taken: 0.00251 seconds
Time Before: 0.04108 seconds
Time After: 0.04850 seconds
Time Taken: 0.00742 seconds
Time Before: 0.05850 seconds
Time After: 0.05888 seconds
Time Before: 0.06129 seconds
Time After: 0.06249 seconds
Time Before: 0.05788 seconds
Time After: 0.06267 seconds
Time Taken: 0.00479 seconds
Time Before: 0.10998 seconds
Time After: 0.11014 seconds
Time Before: 0.13615 seconds
Time After: 0.13749 seconds
Time Taken: 0.00134 seconds
End call of global.php: 0.13986492156982
Time Before: 0.15462 seconds
Time After: 0.15480 seconds
Time Before: 0.15775 seconds
Time After: 0.15923 seconds
SET lastactivity = 1784744932, location = '/forums/private.php?do=newpm&explain=1&u=20589'
Time Before: 0.18134 seconds
Time After: 0.18167 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.18028998374939 seconds with 9 queries, spending 0.0081806182861328 doing MySQL queries and 0.17210936546326 doing PHP things.
