Time Before: 0.01864 seconds
Time After: 0.02630 seconds
Time Taken: 0.00766 seconds
Time Before: 0.02638 seconds
Time After: 0.02684 seconds
Time Before: 0.02712 seconds
Time After: 0.02728 seconds
Time Before: 0.02801 seconds
Time After: 0.03081 seconds
Time Taken: 0.00280 seconds
Time Before: 0.02733 seconds
Time After: 0.03505 seconds
Time Taken: 0.00772 seconds
Time Before: 0.04238 seconds
Time After: 0.04284 seconds
Time Before: 0.04537 seconds
Time After: 0.04664 seconds
Time Before: 0.04170 seconds
Time After: 0.04683 seconds
Time Taken: 0.00513 seconds
Time Before: 0.08850 seconds
Time After: 0.08867 seconds
Time Before: 0.10634 seconds
Time After: 0.10763 seconds
Time Before: 0.11707 seconds
Time After: 0.11725 seconds
Time Before: 0.11934 seconds
Time After: 0.12091 seconds
Time Taken: 0.00157 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=20627' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.13835 seconds
Time After: 0.13866 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
