Time Before: 0.00643 seconds
Time After: 0.01057 seconds
Time Taken: 0.00414 seconds
Time Before: 0.01067 seconds
Time After: 0.01110 seconds
Time Before: 0.01136 seconds
Time After: 0.01150 seconds
Time Before: 0.01243 seconds
Time After: 0.01510 seconds
Time Taken: 0.00267 seconds
Time Before: 0.01158 seconds
Time After: 0.01904 seconds
Time Taken: 0.00746 seconds
Time Before: 0.02392 seconds
Time After: 0.02435 seconds
Time Before: 0.02759 seconds
Time After: 0.02880 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02323 seconds
Time After: 0.02901 seconds
Time Taken: 0.00578 seconds
Memory After: 2,261.836 KB
Time Before: 0.04517 seconds
Time After: 0.04541 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05386 seconds
Time After: 0.05516 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.06098 seconds
Time After: 0.06112 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06342 seconds
Time After: 0.06513 seconds
Time Taken: 0.00171 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789018755, location = '/forums/private.php?do=newpm&explain=1&u=20657' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08296 seconds
Time After: 0.08331 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
