Time Before: 0.01728 seconds
Time After: 0.02138 seconds
Time Taken: 0.00411 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02149 seconds
Time After: 0.02191 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02212 seconds
Time After: 0.02225 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02312 seconds
Time After: 0.02545 seconds
Time Taken: 0.00233 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02232 seconds
Time After: 0.02987 seconds
Time Taken: 0.00755 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03781 seconds
Time After: 0.03823 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04142 seconds
Time After: 0.04263 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03697 seconds
Time After: 0.04290 seconds
Time Taken: 0.00593 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.08075 seconds
Time After: 0.08106 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.13677 seconds
Time After: 0.13800 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
Time Before: 0.16567 seconds
Time After: 0.16583 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.17200 seconds
Time After: 0.17350 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=20747' WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.20125 seconds
Time After: 0.20160 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
