Time Before: 0.02562 seconds
Time After: 0.02976 seconds
Time Taken: 0.00414 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02987 seconds
Time After: 0.03031 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03058 seconds
Time After: 0.03074 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03144 seconds
Time After: 0.03417 seconds
Time Taken: 0.00274 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03081 seconds
Time After: 0.03809 seconds
Time Taken: 0.00728 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04416 seconds
Time After: 0.04444 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04627 seconds
Time After: 0.04750 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.04359 seconds
Time After: 0.04773 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.10463 seconds
Time After: 0.10479 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.17878 seconds
Time After: 0.18007 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.18211913108826
Time Before: 0.21895 seconds
Time After: 0.21917 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.22781 seconds
Time After: 0.22925 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1773147303, location = '/forums/private.php?do=newpm&explain=1&u=20759', badlocation = 1
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.26677 seconds
Time After: 0.26705 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.26571106910706 seconds with 9 queries, spending 0.008242130279541 doing MySQL queries and 0.25746893882751 doing PHP things.
