Time Before: 0.00380 seconds
Time After: 0.00505 seconds
Time Before: 0.00512 seconds
Time After: 0.00548 seconds
Time Before: 0.00571 seconds
Time After: 0.00584 seconds
Time Before: 0.00670 seconds
Time After: 0.00905 seconds
Time Taken: 0.00235 seconds
Time Before: 0.00591 seconds
Time After: 0.01299 seconds
Time Taken: 0.00708 seconds
Time Before: 0.01560 seconds
Time After: 0.01600 seconds
Time Before: 0.01877 seconds
Time After: 0.01999 seconds
Time Before: 0.01491 seconds
Time After: 0.02024 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02788 seconds
Time After: 0.02821 seconds
Time Before: 0.03195 seconds
Time After: 0.03341 seconds
End call of global.php: 0.036038875579834
Time Before: 0.03855 seconds
Time After: 0.03873 seconds
Time Before: 0.04145 seconds
Time After: 0.04289 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=20761', badlocation = 1
Time Before: 0.05833 seconds
Time After: 0.05872 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.057347059249878 seconds with 9 queries, spending 0.0082647800445557 doing MySQL queries and 0.049082279205322 doing PHP things.
