Time Before: 0.00226 seconds
Time After: 0.00318 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00325 seconds
Time After: 0.00378 seconds
Time Before: 0.00398 seconds
Time After: 0.00412 seconds
Time Before: 0.00502 seconds
Time After: 0.00771 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00420 seconds
Time After: 0.01234 seconds
Time Taken: 0.00815 seconds
Time Before: 0.01450 seconds
Time After: 0.01495 seconds
Time Before: 0.01753 seconds
Time After: 0.01880 seconds
Time Before: 0.01386 seconds
Time After: 0.01908 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02845 seconds
Time After: 0.02869 seconds
Time Before: 0.03092 seconds
Time After: 0.03229 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.035406112670898
Time Before: 0.03689 seconds
Time After: 0.03707 seconds
Time Before: 0.04009 seconds
Time After: 0.04156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=20776', badlocation = 1
WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.05538 seconds
Time After: 0.05563 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.054471969604492 seconds with 9 queries, spending 0.0085928440093994 doing MySQL queries and 0.045879125595093 doing PHP things.
