Time Before: 0.00543 seconds
Time After: 0.00654 seconds
Time Taken: 0.00111 seconds
Time Before: 0.00663 seconds
Time After: 0.00708 seconds
Time Before: 0.00745 seconds
Time After: 0.00768 seconds
Time Before: 0.00852 seconds
Time After: 0.01080 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00776 seconds
Time After: 0.01541 seconds
Time Taken: 0.00765 seconds
Time Before: 0.01823 seconds
Time After: 0.01864 seconds
Time Before: 0.02121 seconds
Time After: 0.02243 seconds
Time Before: 0.01750 seconds
Time After: 0.02266 seconds
Time Taken: 0.00516 seconds
Time Before: 0.03306 seconds
Time After: 0.03322 seconds
Time Before: 0.03502 seconds
Time After: 0.03628 seconds
End call of global.php: 0.038522005081177
Time Before: 0.03993 seconds
Time After: 0.04021 seconds
Time Before: 0.04286 seconds
Time After: 0.04433 seconds
SET lastactivity = 1782843106, location = '/forums/private.php?do=newpm&explain=1&u=20840'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.06116 seconds
Time After: 0.06146 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.060240030288696 seconds with 9 queries, spending 0.0080490112304688 doing MySQL queries and 0.052191019058228 doing PHP things.
