Time Before: 0.00127 seconds
Time After: 0.00169 seconds
Time Before: 0.00176 seconds
Time After: 0.00218 seconds
Time Before: 0.00242 seconds
Time After: 0.00254 seconds
Time Before: 0.00328 seconds
Time After: 0.00578 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00258 seconds
Time After: 0.00941 seconds
Time Taken: 0.00683 seconds
Time Before: 0.01147 seconds
Time After: 0.01186 seconds
Time Before: 0.01502 seconds
Time After: 0.01621 seconds
Time Before: 0.01061 seconds
Time After: 0.01651 seconds
Time Taken: 0.00590 seconds
Time Before: 0.02334 seconds
Time After: 0.02347 seconds
Time Before: 0.02522 seconds
Time After: 0.02643 seconds
Time Before: 0.02941 seconds
Time After: 0.02954 seconds
Time Before: 0.03211 seconds
Time After: 0.03360 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=2091', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04872 seconds
Time After: 0.04899 seconds
Memory Before: 4,911.875 KB
Memory After: 4,912.102 KB
