Time Before: 0.01639 seconds
Time After: 0.01918 seconds
Time Taken: 0.00279 seconds
Time Before: 0.01930 seconds
Time After: 0.01979 seconds
Time Before: 0.02188 seconds
Time After: 0.02214 seconds
Time Before: 0.02307 seconds
Time After: 0.02583 seconds
Time Taken: 0.00276 seconds
Time Before: 0.02221 seconds
Time After: 0.03022 seconds
Time Taken: 0.00801 seconds
Time Before: 0.03669 seconds
Time After: 0.03718 seconds
Time Before: 0.04059 seconds
Time After: 0.04180 seconds
Time Before: 0.03584 seconds
Time After: 0.04204 seconds
Time Taken: 0.00620 seconds
Time Before: 0.07077 seconds
Time After: 0.07095 seconds
Time Before: 0.08099 seconds
Time After: 0.08228 seconds
End call of global.php: 0.084328174591064
Time Before: 0.09128 seconds
Time After: 0.09175 seconds
Time Before: 0.09472 seconds
Time After: 0.09616 seconds
SET lastactivity = 1776901768, location = '/forums/private.php?do=newpm&explain=1&u=20951', badlocation = 1
Time Before: 0.11757 seconds
Time After: 0.11823 seconds
Time Taken: 0.00066 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.11627101898193 seconds with 9 queries, spending 0.0092487335205078 doing MySQL queries and 0.10702228546143 doing PHP things.
