Time Before: 0.00756 seconds
Time After: 0.01291 seconds
Time Taken: 0.00536 seconds
Time Before: 0.01298 seconds
Time After: 0.01340 seconds
Time Before: 0.01364 seconds
Time After: 0.01377 seconds
Time Before: 0.01468 seconds
Time After: 0.01745 seconds
Time Taken: 0.00277 seconds
Time Before: 0.01384 seconds
Time After: 0.02263 seconds
Time Taken: 0.00878 seconds
Time Before: 0.02841 seconds
Time After: 0.02885 seconds
Time Before: 0.03064 seconds
Time After: 0.03200 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02764 seconds
Time After: 0.03221 seconds
Time Taken: 0.00457 seconds
Memory After: 2,261.836 KB
Time Before: 0.04475 seconds
Time After: 0.04495 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05406 seconds
Time After: 0.05526 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.057055950164795
Time Before: 0.06010 seconds
Time After: 0.06030 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06260 seconds
Time After: 0.06414 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789137210, location = '/forums/private.php?do=newpm&explain=1&u=21009', badlocation = 1
Time Before: 0.08245 seconds
Time After: 0.08278 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.081300020217896 seconds with 9 queries, spending 0.0085842609405518 doing MySQL queries and 0.072715759277344 doing PHP things.
