Time Before: 0.00193 seconds
Time After: 0.00252 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00263 seconds
Time After: 0.00306 seconds
Time Before: 0.00331 seconds
Time After: 0.00347 seconds
Time Before: 0.00415 seconds
Time After: 0.00677 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00352 seconds
Time After: 0.01014 seconds
Time Taken: 0.00662 seconds
Time Before: 0.01188 seconds
Time After: 0.01231 seconds
Time Before: 0.01553 seconds
Time After: 0.01676 seconds
Time Before: 0.01128 seconds
Time After: 0.01700 seconds
Time Taken: 0.00572 seconds
Time Before: 0.02302 seconds
Time After: 0.02321 seconds
Time Before: 0.02500 seconds
Time After: 0.02623 seconds
End call of global.php: 0.027904033660889
Time Before: 0.02902 seconds
Time After: 0.02917 seconds
Time Before: 0.03132 seconds
Time After: 0.03278 seconds
SET lastactivity = 1785284669, location = '/forums/private.php?do=newpm&explain=1&u=21018'
Time Before: 0.04924 seconds
Time After: 0.04957 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.048321008682251 seconds with 9 queries, spending 0.0082247257232666 doing MySQL queries and 0.040096282958984 doing PHP things.
