Time Before: 0.02195 seconds
Time After: 0.03397 seconds
Time Taken: 0.01201 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.03408 seconds
Time After: 0.03461 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.03491 seconds
Time After: 0.03506 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.03589 seconds
Time After: 0.03849 seconds
Time Taken: 0.00260 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.03514 seconds
Time After: 0.04279 seconds
Time Taken: 0.00765 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.05672 seconds
Time After: 0.05714 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.05946 seconds
Time After: 0.06067 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.05590 seconds
Time After: 0.06090 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.09236 seconds
Time After: 0.09256 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.12563 seconds
Time After: 0.12693 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
Time Before: 0.13932 seconds
Time After: 0.13950 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.14262 seconds
Time After: 0.14409 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=21038' WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.16726 seconds
Time After: 0.18132 seconds
Time Taken: 0.01407 seconds
Memory Before: 4,919.109 KB
Memory After: 4,919.352 KB
