Time Before: 0.02119 seconds
Time After: 0.02675 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02687 seconds
Time After: 0.02735 seconds
Time Before: 0.02758 seconds
Time After: 0.02772 seconds
Time Before: 0.02854 seconds
Time After: 0.03103 seconds
Time Taken: 0.00249 seconds
Time Before: 0.02777 seconds
Time After: 0.03519 seconds
Time Taken: 0.00742 seconds
Time Before: 0.04114 seconds
Time After: 0.04162 seconds
Time Before: 0.04421 seconds
Time After: 0.04553 seconds
Time Taken: 0.00133 seconds
Time Before: 0.04039 seconds
Time After: 0.04578 seconds
Time Taken: 0.00540 seconds
Time Before: 0.07921 seconds
Time After: 0.07940 seconds
Time Before: 0.09541 seconds
Time After: 0.09670 seconds
Time Before: 0.10531 seconds
Time After: 0.10551 seconds
Time Before: 0.10842 seconds
Time After: 0.10991 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=21087' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12868 seconds
Time After: 0.12898 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
