Time Before: 0.00629 seconds
Time After: 0.00819 seconds
Time Taken: 0.00190 seconds
Time Before: 0.00828 seconds
Time After: 0.00868 seconds
Time Before: 0.00890 seconds
Time After: 0.00905 seconds
Time Before: 0.00987 seconds
Time After: 0.01236 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00917 seconds
Time After: 0.01634 seconds
Time Taken: 0.00717 seconds
Time Before: 0.02023 seconds
Time After: 0.02042 seconds
Time Before: 0.02284 seconds
Time After: 0.02418 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01956 seconds
Time After: 0.02439 seconds
Time Taken: 0.00483 seconds
Time Before: 0.03659 seconds
Time After: 0.03674 seconds
Time Before: 0.04191 seconds
Time After: 0.04320 seconds
Time Before: 0.04797 seconds
Time After: 0.04816 seconds
Time Before: 0.05088 seconds
Time After: 0.05236 seconds
UPDATE session SET lastactivity = 1785322117, location = '/forums/private.php?do=newpm&explain=1&u=21209', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.06745 seconds
Time After: 0.06774 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
