Time Before: 0.00147 seconds
Time After: 0.00213 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00220 seconds
Time After: 0.00270 seconds
Time Before: 0.00301 seconds
Time After: 0.00320 seconds
Time Before: 0.00393 seconds
Time After: 0.00630 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00324 seconds
Time After: 0.00972 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01182 seconds
Time After: 0.01201 seconds
Time Before: 0.01489 seconds
Time After: 0.01614 seconds
Time Before: 0.01108 seconds
Time After: 0.01631 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02125 seconds
Time After: 0.02138 seconds
Time Before: 0.04362 seconds
Time After: 0.04486 seconds
End call of global.php: 0.046647071838379
Time Before: 0.04822 seconds
Time After: 0.04838 seconds
Time Before: 0.05051 seconds
Time After: 0.05193 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=21237', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.06438 seconds
Time After: 0.06462 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.06348705291748 seconds with 9 queries, spending 0.0076789855957031 doing MySQL queries and 0.055808067321777 doing PHP things.
