Time Before: 0.00563 seconds
Time After: 0.00799 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00809 seconds
Time After: 0.00861 seconds
Time Before: 0.00887 seconds
Time After: 0.00903 seconds
Time Before: 0.00981 seconds
Time After: 0.01253 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00909 seconds
Time After: 0.01676 seconds
Time Taken: 0.00766 seconds
Time Before: 0.02131 seconds
Time After: 0.02172 seconds
Time Before: 0.02437 seconds
Time After: 0.02559 seconds
Time Before: 0.02063 seconds
Time After: 0.02577 seconds
Time Taken: 0.00513 seconds
Time Before: 0.03947 seconds
Time After: 0.03963 seconds
Time Before: 0.04608 seconds
Time After: 0.04737 seconds
End call of global.php: 0.049449920654297
Time Before: 0.05290 seconds
Time After: 0.05307 seconds
Time Before: 0.05502 seconds
Time After: 0.05661 seconds
Time Taken: 0.00159 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=21254'
Time Before: 0.07219 seconds
Time After: 0.07244 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.071097850799561 seconds with 9 queries, spending 0.0084867477416992 doing MySQL queries and 0.062611103057861 doing PHP things.
