Time Before: 0.00144 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00244 seconds
Time Before: 0.00270 seconds
Time After: 0.00282 seconds
Time Before: 0.00361 seconds
Time After: 0.00619 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00290 seconds
Time After: 0.01072 seconds
Time Taken: 0.00782 seconds
Time Before: 0.01303 seconds
Time After: 0.01325 seconds
Time Before: 0.01486 seconds
Time After: 0.01606 seconds
Time Before: 0.01222 seconds
Time After: 0.01630 seconds
Time Taken: 0.00409 seconds
Time Before: 0.02441 seconds
Time After: 0.02474 seconds
Time Before: 0.02753 seconds
Time After: 0.02885 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03284 seconds
Time After: 0.03370 seconds
Time Taken: 0.00086 seconds
Time Before: 0.03582 seconds
Time After: 0.03725 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=21256', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05299 seconds
Time After: 0.05331 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
